Brian.Evans
Registered Member
- Aug 20, 2011
Hey guys. Working through my first couple. These are A2 3/32x1. I have one more I'd like to get cut out, basically the same as the top knife except with a longer handle.
Stuff I know is wrong.
#1:
I cut the choil before I did the grind. I had to keep moving the plunge back, which made my choil huge. Not happy about that but there it is. The pin hole is too high by about 1-2 mm, which throws off the whole lines of the knife. The grind line goes all the way to the top of the blade instead of stopping a mm short. The file work was just for screwing around. No other knives are going to have it until I figure out the basics.
#2:
I cut this plunge with a round file then cut over to it with my grinder, then squared it up with a square file. My 2x42 doesn't have a ceramic platen on it yet, so I didn't get the grind line sharp at all. The belt skipped over the edge a could of times, causing the issues you see here with what appears to be a washed out plunge line. I think with some steel backed hand sanding I can clean it up well. I need to run this over 240 or 400 first to even everything up and see where I'm at then. Not sure if I want a double or a single pin on this one.
I'd like opinions and criticisms please. Make me better, don't be an ass, but please tell me what I've done wrong so I can grow.
#1:
#2:
