Mendowood cane.
Rusty
Moderator
Moderator
http://www.mendowood.com
I got it in a while back and promised to report on it once I had a chance to use it a while. Now's the time.
Mendowood makes several styles. Freestyles and shillelaghs are heaviest, then the Mendocino, with Sonoma and Manhattan the lightest.
My freestyle arrived at 40 ozs, or 2&1/2 lbs. Another I originally intended to order was 3 pounds.
To my mind the Mendowood canes are a low profile defensive device. The heads are all wood of various kind and shapes. Holding the head and shaft together is an aluminum rod close to half or 3/4 inch going deeply into the head and likewise into the shaft, then glued and pinned. The shafts are likewise made all the same way. A hardwood inner core glued into galvanized steel tubing either 1/2 or 3/4 inch diameter, and then covered with epoxy coating applied to make it look as if the shaft were gloss black coated wood. It achieves that effect very well.
Mine is too heavy to use as a fighting cane would normally be used. It is overly heavy for single handed quick moves. Used as a hand-and-a-half weapon, however, I believe it should be capable of breaking and/or crushing nearly any bone, even from the back of the upper leg. It is, in fact, a club rather than a cane. Held about a third of the way down and with two-thirds in front to balance it, or two handed from any position it works well.
I believe if you are strong and purchase a lighter cane, though, such as the Manhattan model, it would perform quite well as a defensive cane singlehanded. I'm considering buying a lighter one to do just that in a few months.
To sum up, get a lighter, pretty one and it won't raise any eyebrows. It doesn't look like a fighting cane. It doesn't look like a lead pipe either, but that's what the heavier ones amount to. Yeah, I like it, but mine turned out a 20" AK rather than a GS or 20" Sirupati. End of report.
We won't rest until we see close up pics of the shattered bones...
munk
I anticipate a small problem with that as in exigency I'm afraid my initial reaction will be a 14 shot burst followed by a brief pause and then a 13 round burst. If you don't think a revolver or autoloading pistol can be fired full auto you haven't seen me scared.
I had a Ml Garand go full auto on me once.
What do you carry, Rusty? Hi power? Smith? EAA witness?
munk
I already done told you in the "carjacking" thread.
Is it light enough to be used as a cane without notice or is it a club?
The paint look like it has a shine . How do you maintain the finish an is it durable?
That sounds like a pretty good idea whether I really need a cane or not. Don't sound like you can complain about the strength factor. So, I guess if a guy really got in a hurry he would be better off with the Manhatten? In a hurry to move the canee into action is what I meant.:)
That's right Pappy. I may be wrong about the particular models, but I'd bet when you called up the guy and asked for a light cane X inches long he could tell you which were how heavy. And the lighter ones would be just as dense, though thinner. So they should still be one hell of a surprise to someone picking on a helpless old geezer. And leave a lasting impression, so to speak.
If I posted pics, I would probably end up making future posts from "Greystone U."
That is, if they allowed their students access, which I doubt. They don't even allow them phone access without monitoring except to their attorneys.
They do allow them tv and radios in the "dorms", but I don't care for the way the rooms are laid out with 3 solid concrete walls and one wall open except for the steel bars.
Off campus priviledges are likewise limited, if you understand what I mean.
:D Rusty, they look very well made and sturdy.Can't believe the shaft is all metal.VERY NICE!!!!!!;) FC.
NO, it isn't all metal. the top wood is drilled to take 1/2 or 3/4 inch aluminum rod, which is inserted into metal tubing but just for a few inches at the top. Inside the shaft is a hardwood dowel inserted and glued so the metal tubing keeps it from breaking. The hardwood inside the tubing keeps it from bending. Then the epoxy coat on the outside keeps it from looking suspicious.
Those things sound like a winner to me. And, a bit less of an attention getter than a khuk.:)
