- Nov 27, 2004
I intend to use this thread as a space to talk about my new PSK, share some thoughts on its purpose and contents, and in-action reviews. Enjoy!
- Mike
UPDATED NOV 16 - SEE PAGE 2
PART I - DESIGN
Hi all,
Well, I have been doing a lot of thinking about my PSK setup lately, and I decided to set about creating a new kit - hopefully the last one I will make for the foreseeable future.
This is intended to be a fairly comprehensive kit that can be attached to my day pack or hiking pack, or included with my fishing gear.
One of the main issues I wanted to address with this kit is the tension between a ‘just in case’ set of survival gear and a group of handy items that are intended to see regular use. In the past, I have packed the former and the latter together in ways that made easy access a bit of a hassle. I think everyone will agree that it’s important to have a PSK that you can and do use regularly. This means opening your kit up in all sorts of situations, from warm, sunny days to cold, rainy ones, misty mornings, nights, and in the middle of snowstorms. Having a kit that can be easily accessed and re-packed without making a mess of things is important.
Major considerations for this PSK:
Thorough
Not too heavy / bulky
Organized and easy to access
Weatherproof
It will be carried as an attachment to another pack, and so it should always be accompanied by my Kewl canteen and / or water bladder, belt knife, and multitool.
So, here goes. Comments most welcome!
For the PSK pack, I opted for a Mountain Equipment Co-Op (MEC) Bon Vivant. It’s a 420-denier nylon shoulder bag with a detachable and adjustable strap, plus a wide belt loop. The dimensions are listed as 6 x 14 x 23cm. It has a top-access main pouch, a side access zippered pouch, a buckled pouch on the front, and a small zipper pouch on top.
The bulk of my survival gear will go in the main pouch. I decided to put it in a case that can be removed without detaching the PSK from my pack. A Pelican 1050 micro case fits in the main pouch perfectly. It also has a clear top and good clasps, and it is waterproof and tough as nails. I can set it on the ground, open it and rummage through it, and repack it easily. Items can be set on the open lid if I find it necessary to dig around in the kit. The shoulder strap for the PSK is detached and folded up at the bottom of this pouch. If need be, I can rig the kit up as a stand-alone shoulder-slung mini-pack (handy for short spins the the canoe). The case contains my fire kit, a flashlight (Sun eco-twister), hand sanitizer, space blanket (still in the package. I figure that in a survival situation, I will look at that picture and draw some comfort from the fact that I won’t feel quite as rough as that poor chap in the front of the canoe), duct tape, a Fox 40 whistle, and a few large garbage bags.
As regards fire ...
I think I have this base covered nicely! The kit contains a mag block and fire steel, with a JK Nessie tin knife as a striker. It also includes some matches and a mini-bic. I also found a nice plastic container (originally for holding push pins) and packed it full of PJCB’s. This little container is perfect, as it is wide and flat, which allows for easy access to the cotton balls. I often see PJCB’s stored in tubular containers that can be difficult (and messy!) to access. An elastic band attaches the PJCB container to some folded newsprint, which can be used as tinder, and as a base to catch magnesium scrapings.
The zippered side pouch contains my first aid materials and a spare fixed blade - in this case, my Becker Necker. If I have to use this blade, it means that I have probably already lost my EDC scandi and my belt knife. I shudder to think of such a situation!
The first aid kit is in a large ziploc bag. It contains an assortment of band-aids, sterile pads, gauze, medical tape, water purification tablets, pain meds, cold & flu tablets, and antihistamines. I like being able to access my first aid stuff without having to remove the PSK or dig through its other contents.
The top pouch contains my compass. I like to keep this handy, especially during the winter when I’m snowshoeing through deep powder, the sun is hidden by clouds or snow, and everything looks the same (my idea of a perfect outing!).
The front pouch expands nicely, which makes it perfect for storing my bandana and a toque. Those of you down south may chuckle at the idea of including a toque in a PSK during the summer, but it actually dropped down to 7 Celsius overnight when I was up on Blue Mountain a few weekends ago! In the winter, when I am wearing the toque regularly, I will add something more practical to the kit instead.
All for now - Now I have to get out and use it!
- Mike
- Mike
PART I - DESIGN
Hi all,
Thorough
Weatherproof
As regards fire ...
- Mike
