- Jan 27, 2008
"Mesgi'g Tia'm" (pronounced mes-kiig di-aam) means "Big Moose" in the language of the local Mi'kmaq First Nation's People's here on Cape Breton. The Moose antler used in this piece was given to me by a member of the Membertou band of the Mi'kmaq.
The blade was forged from a 5/8" bar. The Ipe handle was a real PITA to achieve a proper finish. I first applied a shellac/Tung oil finish, but that didn't work out too well. In the end I hand sanded to 1000 grit then wiped it down very well with acetone to remove the natural oil from the surface then applied five light coats Tung oil and buffed with a clean wheel. I think the Ipe finished up quite well.
This is the first piece I have worked on in three months. On July 22 I had multi-level(c 4-7) spinal fusion surgery. The recovery has been difficult and I still have very little strength in the hands, and I'm unable to put in a full day's work.... but, I'm getting there. So, to mark my "comeback", I put together the largest knife I've made to date!!
Please take a look and offer up your comments and critiques.
-Peter
Mesgi'g Tia'm
Here are the specs:
Blade: 10 1/2" x approx 1/4" of forged 5160 steel, polished forge finish flats, flat ground and hand sanded 600 grit finish and un-sharpened false edge.
Handle: Ipe with a buffed Tung oil, wrought iron guard with a heavy texturing etch and wrist lanyard notch, brass seppa, pinned moose antler and brass spacer, peened 1/8" brass pin. The removable/adjustable leather wrist lanyard has two Ipe beads.
Sheath: Open spine design, 6-7 oz veg tanned leather(RJF) with mink oil finish, two piece moose antler inlay with paste wax finish, brass snap, shoulder strap carry set-up. The leather shoulder strap has two brass fittings.
Here are a few photos:
And... a final shot of the post-op gore:
-Peter
Mesgi'g Tia'm
Here are the specs:
