- Jan 31, 2020
Hey I’m working on a project and I need to make and fix a metal handle to a 2lb 1045 steel axe head. Any advice on how to go about this.
Thank you and it is an odd projectFrankly,needing metal handle on an axe sounds odd...
But if you must,then i'd recommend investing some effort into making it secure/yet not permanent,i.e.keep the options open for later,and not ruin the head with welding.
I'd go about it by measuring the circumference of the eye.
Tin soldering wire works good,as it flexible and after taking the measure of the eye you can then reshape it to find,say,a sch.20-40-whatever pipe closest to it,and creatively smash it to fit the eye.
If solid steel is req'd solder will give you the necessary section,like if you straighten the length and measure it and multiply by 3.14 that'd be the dia. of round stock that you'd need,et c.
Then i suppose you'd forge and/or grind the eye shape out of that correct volume of steel.
Strange undertaking,but good luck with it.Be careful,a steel handle will jar all sorts of anatomy in your hand/arm...![]()
This could work but I am not sure it would make the handle secure enough.Could you shim the hell out of it with lots of pieces of wood, or pieces of old tires or something like that?
I’m just looking for any ideas because I need a starting point.Simply start with your chosen piece of metal and remove anything that doesn't look like a handle. Then proceed to attach to head. Done.
Seriously though you're not giving anyone enough info to give solid advice. What kind of head is it? What kind of metal are you using for the handle, what tools do you have in your shop to do this with, milling machine, welders, etc. And of course the favorite question of all; why.
