- Jan 20, 2002
Hello everybody !
Last week I got a cheap Horizontal-vertical bansaw (finally!)
During the first blade cutting tests, I broke many teeth. Ok, It was
the default blade coming with the saw, very cheap...
Now, I bought good a 18 tpi bi-metal blade and I wonder if I must
use a cutting fluid or a lubricant when I cut metal? This bandsaw
are not made for use cutting fluid system, but would that be a good
idea to apply a little cutting oil manually? (so yes which kind?)
I imagine that also always should be used the slowest speed?
Do you cut your ATS-34 and 440c dry ?
Thanks !
Alain M-D
Thanks !
Alain M-D
