Metallic Bonded Diamond stones from Practical Sharpening
I'm running through an entire progression on a set of metallic bonded diamond stones from practical sharpening that I recently received in a pass around group right now. 150/300/500/1000/2200/5000.
These stones are pretty impressive. I started with the 150 for the initial reprofilie ot a factory edge. I wasn't aiming to change the edge angle necessarily, the factory grind was just wonky and wavy. This was probably the fastest/easiest reprofile ive done. Great stone for this purpose. The 300 I've used previously, and is a good candidate for your first stone on your routine sharpenings. It does a good job of resetting the bevels without being overly coarse.
The 500 was a real surprise. It was way smoother than I expected. Very pleasant feedback. The 300 felt rougher while sharpening than a coarse dmt, but the 500 feels much smoother than a fine dmt. I really like this stone.
The 1k, and 2200 were no problem, good performance.
The 5k again was fine. The polish left from the 5k wasn't as high as I had hoped, but that ultimately isn't very important to me.
I decided to go ahead and finish on a ceramic stone per usual, loaded with diamond spray. I did some burr reduction, then actually went back to the 5k and did some alternating honing passes. I checked the edge on a hair prior to stropping, and it is the sharpest edge straight off the stones I've ever achieved, and maybe one of my sharpest edges ever. Hairs just jumping off the edge. Very cool.
Initial thoughts after first full sharpening: If you like sharpening with diamond plates, but dislike how they wear, and lose their aggression, and having to guess at how much sharpening life they have left, these are an excellent option. Being able to etch them and bring back the initial aggression is an amazing quality. You can also customize the aggression to your taste depending on etch time. Generally speaking I think they leave a finer, more consistent scratch pattern, with shallower scratches. If you like sharpening on Japanese waterstones, and are looking for a diamond stone that feel like waterstones, these probably aren't for you.
When you say the 500 was smoother than a fine DMT, it seems like the stones rated on the FEPA-F standard.
But then there are the 220 and 5K stones, which sounds a lot more like JIS (waterstone) standard. Otherwise 5K is far finer than any diamond whetsone I've heard of. And that range of stones makes a lot more sense in the JIS.
They have a F2000 witch is the same as an 8K Japanese water stone they do get pretty fine for diamond stones.
I have been watching the forum for a bit now and I'm not much for forums but I just wanted to say that me and a few friends got are metallic bonded cbn stones from a place called sharpeningstones.ru
My 2000 fepa grit stone was 3900 rubles witch worked out 60.20 usd funds,me and my 4 friends who got stones from this website never had any problems at all and we used ems shipping and are stuff cam in just over a week.
If you mean DMT's David I'm pretty sure they Jis but I'm not 100% on that either.
They don't make them any bigger and for the speed they cut at even at 1 inch I don't think most people will care.
If there are stones out there that cut faster then these stones I haven't tried them and I have tried a bunch of them.
Those are small for free hand sharpening. DM
For traditional bench style sharpening they are, but not impossible. I sharpen stone in hand, stone held between thumb and middle finger, knife on other. For this they are just about perfect. And as a bonus these aren't mounted on point aluminum blanks like most stones designed for the edge pro. Those things can be painful, especially if you're using water as a lubricant, softens the skin.
Yes they are quite impressive in that regard. Like I said, not the best polishers in the world of you're into aesthetics, but the scratch pattern left by the 5k could easily be cleaned up by a 4k diamond matrix stone, or even a non diamond/cbn stone. Just use light pressure, maybe back the angle off a fraction of a degree, just tickle the apex if anything, and you can go on about your business. Some moderately heavy stropping might be good enough even, although I've been trying to go a lot lighter on the strops lately.
Regarding these stones polishing capabilities, it just occurred to me that all three stones were fresh off an etch. Polish may go up a bit with a little break in.
I find even on really tough super steels after going up to the highest grit Metallic stone and then using a Chosera 5K does a really good at removing scratch's and then using higher grit water stones.
I do that sometimes is I'm going to be doing a polished edge and I need to set the bevels or reset them.
