I add just a quick one..
RLB file steel? are you stock grinding or forging??
I have not cracked a blade in 32 years..of which 24 were with high carbon steel only.. I've left quenched blades so long I've forgotten if I tempered them or not
.. so I'd temper them anyway again if for only not knowing..
this is not to say if you do not temper ASAP you would not have a blade or two crack on you..I'll call it luck on my part..know your steel and the heats..
with the SS I do snap temper and Cryo ASAP. then temper them again, the 2nd temper I don't worry about the time that goes by .it's just the way I do the SS..I've only been at the SS for about 8 years now..
it's been said many times and I believe it very true.. if your nail your H/T correctly you'll have less problems later in every aspect.. I will say , I'm mostly a stock grinder in comparison to my forging
my stock grind forged steel comes from the steel foundry where as all steel is forged to start with..
and I would guess most of the time will not be forged incorrectly after all this is where steel comes from these days .
too, I will back ED up ( not that I need to
) in saying, you can mess up perfectly good steel by forging it if you don't know what you are doing..
