- Jun 6, 2017
Or how to really tick off a lot of knifemakers.
Canvas, paper, linen, wood, fiberglass, carbon fiber or any of hundreds of different materials were and are currently used in thermosetting plastics or "phenolic resin" by then Westinghouse Micarta and later Micarta Industrial and now Norplex-Micarta.
My point here is either call all phenolic resin laminates "micarta" or don't call any that because it's just plain lack of logic to call only a select few micarta while at the same time argue like some here have that the other myriad of thermosetting plastic laminates made by micarta somehow are not also micarta, I call BS on that thought process. They all are or they all are not.
All inclusive or non inclusive that should be the take away here, I say none should be called micarta that would simplify everything and if I owned the name no one would be abusing it.
As shown by other members elsewhere here in old ads there were many different thermosetting plastic laminates included under the micarta name originally used not just canvas, linen and paper some other materials are noted above so I have been proven correct that many more materials fall into the thermosetting category, thanks to those participating and for substantiating my claims which was easily confirmed with little research.
Argue all you want but the truth has been presented and verified. Excerpt from WH media ad
"Micarta is a Westinghouse trade-name that covers all of the molded products manufactured by the Micarta Division. It is a plastic material using paper, cotton cloth, wood or fiberglass as filler materials. The fillers are impregnated with a fluid synthetic resin that is composed basically of phenol. When properly compounded with other chemicals this produces a fluid resin that can be changed to a solid by the application of heat. This change from a liquid to a solid is known as polymerization." Today the list of materials used is in the hundreds and still all inclusive under the micarta trade name.
Micarta is nothing more than a brand name of a multitude of thermosetting plastic laminates also known as phenolic resin laminates, stop using the name micarta for a few select products, I know you won't though, I suspect most are as stubborn as I am. Till next time guys.
https://en.m.wikipedia.org/wiki/Micarta
