- Feb 23, 2022
Can one make micarta strips to be laminated as rings around a handle?
Yea I'm thinking rings going around scales of another material, if actual rings can be made to go around something and not just stacking chunks that's awesome. What maintains the rings strength though, would it need to be threaded or sowed together where the two ends meet to make the ring?Like for a hidden tang? IE cut the sheets down and make them into rings like leather washers for a stacked handle? Sure, any material can be used like that pretty much! Micarta, G10, wood, rubber, leather, etc. Micarta also comes in solid blocks, too, but you would have to make the tang slot in it. Rings would be easier and you would see the side grain of the Micarta.
Ah ok, yea I was going to say I thought maybe this would be difficult considering the micarta would have to be made from scratch and isn't there an issue with getting bubbles out of it when making it your self, requires alot of pressure right?What other material? Micarta is rigid; you cannot sew it or wrap it around another material unless you are making it yourself and do it before you soak in epoxy? It may be better if you show us what you are looking at making?? I thought you were asking about a stacked handle setup, which can be done with most materials. If you want to wrap an existing handle, you would need to use something flexible like leather, paracord, jute cord, etc???
Thanks for the insights, I probably wont be going with this method now that I know more.Yu can buy Garolite tubes from places like Mcmaster Carr. It cones in a couple colors and in wall thickness up to 1/4". It is expensive. 1" OD with 1/4" walls is $150 for a 42" piece.
You can also buy carbon fiber tubing.
To make it yourself, you would have to make the MyCarta in a roll fashion. Soak the material in resin and tightly wrap around a center wooden dowel mandrel. Tightly wrap with a rubber strap (the type used for exercise should work well) and let cure. When cured, clean up the outside and slice into discs. Drill out the center wooden part as needed and you have MyCarta rings. Definitely not worth the work, and not real phenolic Micarta. You probably would get a better looking homemade product with carbon fiber sheets.
