I am going to order 2 mora companions today and have Been reading about them and people say to put a microbevel on them to make the stronger. I have done one micro bevel on my old case knife. But anyways I was wondering how do you sharpen a microbevel on a mora? And if you we're to keep sharpening the microbevel wouldn't it keep getting bigger and bigger? And when the microbevel gets big do you just restart and go back to the original grind? It just seems putting a microbevel on a knife is a waste of steel..... I really don't know a lot about microbevels. So could you guys give me some info? Lastly does anybody know what angle mora sharpens their knives?
Thanks
Mora factory edge (on the ones I have bought) is approx 22-24 degrees if measured from the shoulder. They all had a subtle convex from the factory, so closer to 24-26 at the apex. Anyway, if you grind them flat from the shoulder they will most likely be too fragile an edge for good utility. That said, keeping it as close as possible to the flat Scandi profile will have the knife performing best both for green wood bushcrafting and utility use. A microbevel is OK, but you will want to regrind the back bevel nearly every time you touch it up, or the Scandi grind will not perform well. On mine I generally apply an extremely shallow convex, maybe a degree or so from shoulder to apex and this makes for a very strong edge yet still carves wood nicely and is thin enough for utility work.
As I see it - even on other grind types - sabre, flat, etc you will want to grind the back bevel frequently prior to repeatedly applying a microbevel. A relatively broad apex angle is OK if its an extremely small part of the cutting edge - as it gets larger (depends on how often you would need to touch up the edge), performance and longevity will degrade, considerably in some cases. When using microbevels, sooner or later one has to grind a fresh edge to the apex and restore the secondary bevel to a more acute angle, so sooner or later you'll have to remove all the steel you put off doing as you went. There is no net saving of steel, only a saving of time when its still small enough to quickly touch it up.
Additional consideration, they come in very handy for beefing up an edge that's been ground too thin.
There's a real good sticky at the top of the page "Microbevels" that has good info and insight.
I have a too many questions. But you said " A microbevel is OK, but you will want to regrind the back bevel nearly every time you touch it up, or the Scandi grind will not perform well" you said this above. What do you mean by this? And why do you have to regrind the back bevel? Sorry I am kinda new to microbevels.
Thanks
I second all above, would like to add that a microbevel does not guaranty that you don't have a burr which you will have to remove to get a nice, clean, and - the reason you do this in the firts place - strong edge!!
Also, doing a microbevel, since the bevel is so micro, it is difficult to hit the same bevel again when "touching up" so you likely end up putting many different "facetts" on, although this probably does not matter much in terms of performance since it's micro.
Eventually, once the microbevel becomes a macrobevel (hmm, actually before your microbevel becomes a macrobevel ...), you will have to grind back to the original scandi bevel to maintain the performance advantage, the reason a scandi grind exists! Grinding it back to "flat" is not easy, takes time, you will have to go through all the grits etc. So, at the end, if you don't mind going through the process over and over again (depending how much you use your knife and have to sharpen it), a microbevel is ok but you will not be able to "just touch up" the main bevel to prevent the microbevel from coming closer to a macrobevel.
Ok now it is making more sense. But if the micro bevel were to turn into a "Macrobevel" and you wanted to go back the original grind it came with, would you just sharpen the blade at the angle of the original scandi grind to get rid of the "macrobevel"?
Thanks
I usually give 10 - 15 strokes on the original bevel then 4 - 5 strokes on the micro bevel when I sharpen my Moras. Unless I am in a hurry.
