- Mar 5, 2009
So I've got a Wicked Edge Pro kit (and added the ceramic 1200/1600 grit stones) and I have a few lighted loupes / handheld micro-scopes (25x, 45x, 60x) and I'm getting what I would call proficient at sharpening with this thing to a very clean primary edge with a good apex, but I've always had some pre-concieved notions about micro-bevels that I thought I would just verify on here (I searched this sub-section for answers, but didn't find all the info I needed).
If I start out with a 20 degree per side angle, I will typically move out to about 22 or 23 per side for the micro-bevel (pretty much all of my knives are between 18-22 degrees for the primary bevel). Is 2-3 degrees per side for the micro-bevel too much / not enough? I only want a little bit of extra edge-strength (or in the case of S30v, just a little longer retention over that one day or so of sharp edge - wearing into working edge). I seem to be getting good results, but I'm not sure if I could be getting better results.
This leads me to my next question:
How much material should I be taking off when adding a micro-bevel? I've read and watched videos where folks just use 5 micron or 3.5 micron strops (or 1600 grit Ceramic) to add the micro-bevel (with maybe 20 or so very light strokes). Is this enough? I've tried it with just one strop or ceramic stone, and I've tried using both the 1200 and then 1600 ceramic stones and then the 5 micron and then the 3.5 micron (just a few light strokes with all 4), but I think that's too much for just a micro-bevel. How much material do you generally remove to get just a micro-bevel (ballpark estimate in terms of grit/micron and what stones, and what number of strokes)?
Should I be able to see the micro-bevel in a 25x Loupe? In a 45x scope? In a 60x? I feel like in some cases, I'm doing too much, but in others I'm not doing enough to make a difference (I don't seem to be able to tell the difference in edge-performance - but I'm not doing any scientific tests or anything - just normal everyday use).
