- Feb 14, 2010
Most stuff I read talk about applying a micro bevel with just a few light strokes on both sides with the highest grit or maybe 1 stone down. I have also read setting a relief bevel at say 15 degrees then dropping in grit and raising a burr again at 20 degrees and progressing through the stones.
The other night I tried setting a relief bevel at 15 degrees progressing from Shapton 500 up to 6k. Then set the angle to 20 degrees, dropped back down to 2k, raised a burr (didnt' take much), and progressed to 4k and 6k both times raising a burr and removing it at the end. I use a little hand held microscope to help see the burr at that level.
I haven't been sharpening that long but this was by far the sharpest I have got an edge. So my question is... Is there any advantages / disadvantages to doing what I did over just setting a micro bevel with few passes with the highest grit stone? I know that some of this is just terminology but I have seen people say "they call it a micro bevel for a reason". So in this case I would not call what I did a "microbevel" but more a double bevel.
-Steve
-Steve
