- Jun 16, 2005
To begin, I don't like to solder at all, especially micro board stuff. It's one of those things I sometimes have to do, but not enough to be good at it. I use micro wireless video, both professionally and as a hobby. For the hobby part, I use lower end import cameras, because I occasionally destroy them in the application I use them with. These camera's are OK, but invariably has POS power switches. I just had two go on different cameras. My easy fix is just to close then contact point on the board so that the camera is powered whenever hooked to the battery. With these cameras though, the contact distance was about 2mm and some of the surrounding contacts were about 1.5mm away from the pair I needed to connect. Off I went to Radio Shack, to get a low wattage pencil iron. I had a gun that got to hot and would have been to cumbersome. While I was picking out my iron, I saw a Kronus Helping Hands unit on display. For $12.99, this was a no brainer. That, and .015dia. Silver-Bearing Solder, made a job I was a little intimidated by, much easier...
