- Mar 18, 2010
Hello all and happy Friday,
I was just attempting to put the finishing touches on my first attempt at a full convex grind blade before sending off for HT and the belt snapped on me (just a friendly reminder, ALWAYS wear your full face shield, even when you're "just touching something up". I wasn't and while it didn't hurt like I'm sure a Y weight Blaze would, it smarted pretty good).
I was slack grinding about midway between the platen and the idler pulley on a Coote, wasn't at all "leaning into the grind" (just touching up some grind lines). The cutting edge of the blade is still as thick as a dime and was trailing, so I didn't catch an edge and I had only made 3 passes on this side, so no heat build up to speak of. The observant will also note that it didn't turn loose at the joint, it appears to have simply "ruptured", for lack of a better word.
I'm stymied and wanted to see if any of you more seasoned fellers might be able to tell me what I did wrong so I don't repeat this incident. Any and all feedback would be most welcome!
Thanks in advance,
Taylor
Thanks in advance,
Taylor
