- Jan 20, 2001
Hey guys, I just wanted to write up a short review of the MT amphibian.  I picked up a couple of these when Mike Turber was blowing them out a couple of months ago and was able to have them brought down to me here in Central America.  I was/am in the process of having a couple of heavy duty framelocks made and brought down to use as work knives.  These were intended to fill that gap till I could/can get them.
I have been carrying a coated PE 'phib just about everyday since November and have been VERY impressed. I have used it for everything and even tried to do some things I would not normally do with a folder to see if they could take it. On general cutting chores it is a great slicer. I have used it to shred alot of cardboard and fuzzsticks for starting fires and it will go through a ton of cardboard without losing its shaving edge. Being the equivalent of 154cm it is not a "supersteel" but is plenty for daily use. The high flat grind and recurve make it a dynamic cutter. I also use it to trim some of the plant life in the yard such as palms and bananas. If you have ever trimmed a banana tree you'll know that the sap stains horribly but, of course, do nothing to the boron coating. Full elbow swings into palm branches result in nice clean cuts with no chipping or rolling. I also took a rough 1x4 of unknown variety to test chopping. I chopped through it four times without sharpening. Afterward, it would not shave but would still dig into fingernail. There was no chipping or rolling of the edge in spite of the fact that I twisted the blade forceably with each swing to break the chunks of wood free. I also did some moderate force stabs and twists with no damage. The blade, like many MTs, is quite thick and apparently very strong. Afterward, the knife had not developed any blade play and was brought back to hair popping with a few strokes on the medium sharpmaker stones.
The only modifications I have made have been the addition of stingray inserts and reshaping the bottom of the clip. It comes rather square and snagged on many things. I used my dremel to round it to eliminate the snags and it has worked wonderfully. It has proven to be one of my favorite prodos and thanks to being in Central America, I can carry the auto version with no problems. Great knife that I would recommend to anyone!
