- May 12, 2001
I received my Microtech fillet knife via brown truck today from Roger at Bayou Lafourche and wanted to share some initial impressions with those of you who have been interested in this knife.
Overall: Fit and finish are excellent. Feel in the hand is also excellent, in most any grip.
Specs:
Steel: S30V, I do not know the RC
Weight dont know exactly, but the knife is light (maybe 5oz or so)
Handle: Aluminum with Kraton inserts, about 5 long. The handle is held together with three stainless steel torx screws. There are grooves milled into the handle for the thumb, forefinger, and pinky. There is a slight birds beak at the butt of the handle. The handle is flared where it meets the blade to form a natural guard.
Blade: 7 from the handle to the tip and about 2mm thick. Stonewashed. The blade has a little flex towards the last inch or two from the tip, but it is not flexible in the way that the traditional fillet knives such as Gerber, Rapala, and Cold Steel are.
The spine of the blade is nicely rounded and reminds me much of the spine of my Sebenza. The rounded spine makes it pretty easy to choke up on the knife with your thumb. There is a slight upsweep to the blade with a nice belly and a very sharp tip I like the tip. The grind lines are excellent and the tip is ground about perfectly.
Edge angles appear to be less than 20degrees per side, but I cannot say exactly what they are. The edge is very sharp. The best way I can describe the factor edge is that it is a little toothy, like the edge of a Dozier. This may be due to the nature of the S30V steel, the grinding technique, or both. Anyway, it is a great working edge.
Sheath: nicely finished kydex sheath with slots and rivet holes for multiple lashing options. The sheath also has a Tek lock system that appears to allow for horizontal carry. The handle is secured partially by the kydex which fits around the handle, but also by a rubber ring that slips over the butt of the knife. It will take some getting used to, but I anticipate the rubber will loosen up a little. Time will tell how durable this closure is. There is a drainage hole at the very tip of where the blade rests in the sheath.
Balance point about ¾ behind where the handle meets the blade and feels excellent in the hand. Although I consider this to be a kitchen/utility knife, it is very agile in the hand for those of you folks who like that thing.
I soaped up and washed the knife first and noticed that the handle was still grippy even when held with soapy water. My suspicion is that it would do well when covered with fish slime too.
Some simple cutting tests:
Foam packing peanuts went through with very little effort and cut cleanly.
Raw Broccoli excellent cutting with very little force.
Whittling seasoned pine nice shavings were produced with a very clean cut.
Whittling seasoned oak and hickory pretty good at whittling hardwood too
This knife is a SLICER, and it appears that it will meet my primary need as a kitchen/camp/light utility knife. The fit and finish are excellent. Period. Though it is thin and semi-flexible, this knife does what I want a knife to do and that is cut. I have been moving towards thinner knives, and will carry a good hatchet or axe when outdoors.
The feel in the hand and quality of the materials inspires confidence in me. The wife tried it and really liked the way the knife felt, cut and looked. It passed the sheeple-friendly test.
So much for my first impression, I will try to use the knife extensively to post some on the edge durability, ease of touching up/sharpening, etc. I believe this knife to be a very good value and look forward to getting to know it better.
I would have liked to post pictures, if anyone would be willing to do this for the group, please email me and I will send you some pics.
Specs:
