Microtech: Socom Elite or LCC
catmath 1911
Hello All,
which one of these knives, in manual action, would be better for EDC/Utility/Defense? Also could you give pros and cons of each?
Thanks,
catmath 1911
I can't speak for the LCC, not owning one, but my SOCOM Elite is a beautiful, elegant, graceful, tough, sharp, and comfortable piece of cutting equipment. The microbar lock mechanism is a bit tight, which is good. The fit and finish is every bit as good as I've heard about the LCC. If I didn't own all these Sebenzas, I think I would carry the SOCOM E every day myself.
If you get a chance to compare them, be sure to try which is most comfortable in your hand. This is a very personal and individual preference, and the best knife in the world can't suit everyone as far as grip is concerned, although a few do come close.
Check out the weight, too. It may not seem like a big point, but that slighly heavier knife may get tiresome, dragging down a corner of your pocket, or pulling your belt out of line.
The LCC doesn't have a guard or choil to prevent your hand from sliding up on the blade. It is also a little slow to open, a simple flick of the thumb won't do it. It is well built and attractive.
I tried the LCC twice because the blade shape is so perfect, but I couldn't seem to get it together with the handle (just personal preference). Picking up a SOCOM Elite was love at first sight. A little big for my needs so I went and got a Mini SOCOM. It's currently my favorite production knife and the same can be said for the SOCOM Elite as well - same thing just bigger.
A timely question as I made this very same decision while getting dressed this morning. I chose the LCC (m/a, sw). Here's why:
Blade shape and grind: The LCC offers a more useable blade shape, the grind is higher and the edge is consequently thinner. It offers better cutting performance. The SOCOM has a stonger profile for extreme uses and probably better penetration.
Ease of carry: The LCC is tip-up, which I prefer, the SOCOM is tip down, which I don't. The LCC is heavier (and I wish it were lighter). I find that despite its greater weight the LCC carries in the pocket better. The SOCOM is more accessible for a quicker draw.
Looks: I like the carbon fiber and Ti of the LCC (I really need to get a micarta one as well) better than the SOCOM.
Fit and finish: both are perfect. period.
Handle ergonomics: for utility chores (which is what I use a knife for) I find that the LCC fits MY hand better than the socom. It offers a fuller grip and presents the blade at a nice angle relative to the cutting surface, which is good for slicing and push cutting. The SOCOM offers a higher level of security during stabs and slashes, and is better suited for those tasks (which I hope never to have to use a knife for).
Edge durability: Both use 154CM at the same heat treat. Both perform awesome. Both take and hold an edge better than any other 154C</ ATS34 knife that I own. I don't know the specifics of MT's heat treat but for 154CM it performs as well as 154Cm treated by Paul Bos, high praise indeed.
Lock strength: Both have strong locks, but I think that the Microbar is a stronger and more secure lock. The LCC has a thick steel liner, which locks up tight, very secure for a liner lock. The microbar is like a vault, I would rate it as being almost as strong as the frame lock on my Sebenza and equal to the AXIS lock on my 710HS. But I really don't use a folding knife for any tasks which realy strain the lock. In fact most of my daily cutting tasks are done with a SAK, usually a non-locking model like the recruit or tinkerer.
Bottom line: Both are great knives. I find the LCC better suited for utility tasks and consequently my EDC needs. The SOCOM is probably better suited for defensive purposes, but as I have a Sig Sauer 9mm, OC spray and an ASP on my belt, and a shotgun in my patrol car I have tools better suited for a serious social interactions readily at hand, a knife would be my last choice......
For me the LCC is better. Which is better suited for you is a choice that only you can make. Handle both if you can.... either way you'll be making a good choice.
stay sharp,
Chad
having owned both knives,i prefer the LCC over the Socom Elite, they are both nice knives...
but i think for the money, you get more knife with the LCC,nicer materials like ti bolsters and carbon fiber scales,full liners and a great lock up also,
i think the newer LCC's have aluminum bolsters, but that shouldn't take away from the knive, having said that, the Socom also was a very stout made knife...
more tactical than the Lcc, 154cm blade,aluminum handles,with an inlayed lock,(micro bar?) i had never had a prob with that lock before,but i remember a few forum members having some difficulty with them...
i still have and use my LCC...its probably my favorite production knife :)
Whichever you choose, jump in fast, since both knives have been discontinued. Both were only in production for about a year.
I fail to understand the corporate philosophy of a company that will turn out a first-rate product, together with serial numbers and dates of manufacture and then dump it. It speaks poorly for the kind of warranty protection the ultimate purchaser will have. A "lifetime" warranty is only worth the paper it is written on if the company has replacement parts available. If they don't, it's a knife "of comparable value".
The products are totally top notch, but I have serious misgivings about the company policies. If I'm going to spend top dollar, I want to know that my knife will be supported by the manufacturer at least for a reasonable amount of time.
I don't know how worried you should be about Microtech not continuing these lines. The knife business today is highly competitive. Staying with a few basic designs is a risk in itself. Think about automobile models and how often they change.
Does anyone know of an instance in which Microtech was unable to support a discontinued standard model? Of course, many of these knives (like mine!) aren't in heavy daily use.
I'd choose the mini version of the socom.
However, a Small Wood Sebenza is my EDC.
Eric
Thanks to all for their expedient and informative replies. One does wonder about the logic of removing a product from the market not long after it was introduced. On a different note, www.888knivesrus.com lists the LCC for $145. Does anyone know of a more competitive price online? Also, does anyone know if the LCC's at 888knivesrus have titanium or aluminum bolsters?
thanks,
catmath 1911
I have had both the Socom Elite and LCC in MA and i have to say go with the Socom, it's way lighter and i like it's clip point blade better!
The LCC is very well made but it's way too heavy and cumbersome for me as a EDC, i tried it for a while but as RickMaster would say "the LCC makes a good boat anchor". If you don't mind a heavy knife then i see no problem with a LCC. LOL hehe
James
My usual EDC is a large plain Sebenza, I carry a different knife about one day per week, usually rotating between the LCC, SOCOM, Spydie Military and Calypso and a BM710HS.
The fit and finish of the Microtech products is right up there with CRK. I have owned three Sebbies, and can honestly say that the fit and finish of the MT's has been jsut as good.
I like the deeply hollow ground, drop point, BG42 blade and the integral lock of the Sebenza. It is what I find most useful for everday tasks. But it is not a far superior knife to my Microtechs.
In fact if the LCC had Ti liners (making it lighter) it would surpass the Sebenza IMHO.
Chad
I have picked up some great knives at nice prices on our own Exchange Forums. I got my SOCOM Elite in all-but-untouched condition from a fellow forumite. But you won't find many of those for sale. You will find a few LCC offered, though. Hmmm ... (I'm kidding, I'm kidding!)
Go to the individual production knives for sale and do a search for the SE or LCC and see what's available. If you can wait a bit, the exact configuration you like should come up, it will be cheaper than retail, and it will have been checked out by a knowledgeable knifeknut already!
