Mistwalker
- Dec 22, 2007
I have posted some shots from the tests in various areas already, so I thought maybe I should put several in one thread...about 80 I think are here.
I'm not going to do a lot of commentary here, I'll save that for the actual review. However I will say that I have enjoyed using the knife. The fit and finish is what I would expect, the grind is a great one for diverse capabilities, the assembly is very solid, no movement or loosening in use, and the heat treat and edge retention are pretty darn impressive. So impressive I had to get creative to come up with a field expedient method of degrading the edge, that still fell sort of within the realm of reasonable expectation (depending on who you ask), and constituted a real world test, so that I could actually re-sharpen the knife and check ease of field maintenance. You will know this part when you see it...it involves a fire steel. But field maintenance wasn't bad at all and the damage done was cleaned up in just a few minutes time out in the woods, and the knife was quickly back to sharp, and cutting with ease in no time.
