MIG rods for pinning handles?
I picked up some 1/8" Silicon Bronze MIG welding rods. Anyone ever use them for pinning handles on a full tang knife?
Tip o' the day. Whether it is brazing rod, or pin stock or some brass rod in a hobby pack from a craft store (or a piece of wire unwound off something old for that matter) always anneal it before trying to use it. Some wire/rod is work hardened in drawing to a surprising degree and is much too stiff to peen with out cracking. ;)
Ive used quite a bit of the oxy/acet rods that are fluxed. I just break the fux off and lightly sand them.
A welding supply place has many things that can be used as pins.
You can get brass and stainless rod cheaper than most hobby shops.
Just make sure you have a decent asortment of drill bits, 1/8" is not always 1/8", wether it's from a welding shop or knife supply shop.
I curently have 3 lbs. each of brazing rod and 308 stainless rod from a welding supply outfit. The brass is unfluxed torch brazing rod and the stainless is unfluxed tig rod. It'll take a couple of years to use it all up, and if I need to do some brazing in the meantime I'm good to go!:D
Hey guys, thanks for your input. I am still very new to knife making, but I do know I like using any "freebies" I find :D Everything has an intended purpose, and then there's "can I use it in the shop or put it in a knife" purpose.
Only problem with my rods is they come with little stamped marks along along the rod, I assume so one can tell how fast one is pushing the stuff in. Doesn't seem like the perfect stock with those marks.
? with the brazing rods and stainless weld rods I have gotten are just clean, unmarked pins.
My regular steel rods are pretty plain, just some copper coating, but the 316 ones (which I was told I could weld 304 with also) come with each end stamped with the 316 number, and every half inch a little anular groove. Very fancy. They probably know I need the help.
