those look great. your fit to the handle is perfect. many of mine are not that perfect, i dont take the time to get it exact. i just want the wedge tight. many times i have a small gap at the front of the eye.
i have found house handles wedges to be great. i have to thin out and trim the wedges from other companies or i cant get them half way in usually. the house wedges seem to be just about right in the taper department. my kerf is usually only 1/8" or 3/16" wide after fitting the head, so i cant use a fat steep wedge.
are you setting how open or closed the hang is when fitting the head to the haft? a couple of them look slightly open, but its hard to tell without looking at them bit down on a table.
Thanks! My others aren't that perfect. I don't honestly think it's important, but I expect more from myself each time I do one. I split Hedge, Mulberry, Oak, you name it - they stay tight. Although, I just eyeball the fit, and for this KK I only actually fit it, and removed it 3 times. I have the same exact deal you're talking about with the gap toward the front on others. What I did on the last couple was to bring the front of the eye to a point, and do nothing else. I only take material from the back/sides from that point forward. It gets the perfect fit, plus it keeps the head seated forward so that I get that nice angle at the rear of the shoulder - just my personal preference. I don't like the look of an axe that isn't "shouldered up".
I agree about the wedges. My complaint is that they have all been cut too narrow (but I've hung 6 whole axes - not exactly a deep well of experience), by this I mean they are not as wide as the eye is long. Man, I have no idea how to put that into words. These two handles that came today had great wedges - they were both wider than the eye is long. I hope that makes sense. But I agree, with an axe you simply can't use a steep wedge.
I don't pay much attention to the angle of the head - a little open, a little closed I'm ok. I could tell when I cut this KK that it looked up-swept and I would say it really does look open (if I'm following your meaning), however, it actually came out better than I expected it to. I split some Hedge (nice straight stuff though) with it tonight and it worked great. I like a tall (knee high, maybe higher) splitting log so slightly open isn't an issue, particularly with these short handles. If I was chopping trees, I would probably pay better attention. I like to see the wood smears on the head after a cut running at an angle from the middle or lower portion of the bit, upward off the fattest part of the cheeks toward the poll. I know then that I'm less likely to get my handle involved if the piece doesn't split clean through. Of course it helps to make sure the shoulder on the handle is narrower than the axe head. I theorize that for splitting, a little open is possibly a benefit. I've been known to tackle logs that probably should be split with a maul with my axe, so you know .... I accommodate my own habits.
