MIL-TAC MTF-2 With Pouch
For sale; One MIL-TAC MTF-2 Folder. New, never carried or sharpend.
Does not come with box, as I received in a zip-lock bag as part of a larger package. Designed by the great Allen Elishewitz.
Here's the specs,as per MIL-TAC;
Detailed Description
The MTF-2 was designed with military and law enforcement in mind. The liners are made of heat-treated stainless steel which produces a very rigid frame and locking bar. The blade is extra thick to give the user additional tip strength; at the same time the grind lines are high enough to produce a razor sharp blade edge. The handle material is G-10 (a glass phenolic) and is impervious to liquid and temperature changes and is extremely tough for any environment. Added to all these wonderful features is a safety which makes this knife even more indispensable.
This knife was designed as a self-defense tool. The blade is located in the center with a very acute point; this allows effortless penetration. The blade has a slight recurve which amplifies the cutting power. The grip is designed in a way that the user can hold it in any style he or she prefers. And the back end of the handle is shaped in a way that can be used as a blunt striking tool. With the raised & textured spacer and textured handle, the user can have complete control over the knife even if they need to do snap cuts with sweaty hands.
Weight: 5.50 ounces
Blade Length: 4.00 inches
Blade Style: Drop Point
Edge Type: Plain
Blade Finish: Teflon coated blade
Blade Thickness: 0.135 inches
Blade Steel: N690Co Stainless steel
Rockwell Hardness: 58-60
Pocket Clip: Stainless Steel, R/H or L/H reversable, Tip-Up
Closed Length: 5.00 inches
Overall Length: 8.75 inches
Handle Material: CNC machined G10
Locking Mechanism: Stainless steel liner lock
Fittings: Stainless Steel
Retails for $128.00-$168.00
Yours for $85.00, with S&H in the U.S. Money Orders Only, Please
I will throw-in one MIL-TAC Utility Pack with the knife!
http://store.mil-tac.com/index.asp?PageAction=VIEWPROD&ProdID=135
i have a ZT 0650st to trade for your MIL-TAC MTF-2. can email you pictures if you're interested? :)
