Military CPM S110V
I recently picked one of these up because I had no knives in CPM S110V, which is reputedly one of the best edge-holding steels available, as well as being a b*tch to sharpen. The guys down at Cutting Edge in Calgary (the best knife shop in town IMHO) commented that they would have just laughed five years ago if someone had walked in and said he wanted to see something in CPM S110V; it was practically unobtanium just a few years ago.
Tip down, right-side-only is the only carry offered, and the Military in CPM S110V comes in no other versions (there is a lefty available, albeit only in S30V), but it nestles into a right jeans hip pocket against the seam. Takes a bit of getting used to if you favor tip-up. The clip is firm, not impossibly tight, like my Recon 1 – I had to remove and bend the clip on that just to get it to slip over the pocket seam. It rides high enough to get a good grip on the blurple G-10 scales. I may make a simple pouch-style belt sheath just to try that out.
The G10 grips provide excellent feel, no slip, even while wearing gloves (it’s still winter here in Oilberta). The long handle would be useful boning out big game. I’d bet the steel would hold up well even field dressing moose or bear, whose gritty hides will take the edge off about any knife.
There’s a nice curving sweep to the blade, like the Para Military 2; that and the flat grind make it an excellent slicer. Fine tip, but still plenty of steel at the end.
It’s surprisingly light for its size, and the 4” blade is substantial. Just a flip of the thumb in the oversized Spydie hole flicks the blade out. The stiff Walker liner lock clicks solidly into place, as opposed to the softer engagement of the Compression Lock on my Para 2. No flex, no wobble when open. The blade isn’t perfectly centered when closed, likely due to the light pressure of the detent in the liner lock, but it doesn’t even come close to contacting the scales and likely only a knife nerd would even notice.
Fit and finish are as close to perfect as the eye can tell. Spyderco has achieved a level of precision that matches my Sebbie 21. Impressive, to say the least.
So, having fondled it a bit, and not bleeding yet, I headed out to the garage to do some whittling on a stack of nicely dried fir. I briefly considered slicing up a couple of miles of cardboard, hacking through some thick wire cable and plastic zip-ties, but that’s already been done (check out Ankerson’s “Spyderco CPM S110V Military Full Review”).
Five minutes of whittling on a hard fir stick did take that factory-fresh hair-popping edge off. However, 30 seconds on the DMT ultra-fine brought it back to hair-whittling sharp. No complaints so far.
Took it on a two-week road trip south, used it for food prep, opening stuff, a bit of whittling, cut some plastic bottles with no discernible dulling.
There’s been a lot posted here about the difficulty of sharpening S110V, but I don’t find it significantly different than any of the high carbide content powder steels (S30V, S35Vn, CTS-XHP). Gave it a touch-up on the DMT bench stone when I got home, using just the regular (red) grit. Slightly coarser seems to work better for these high carbide content steels, and it’s back to scary sharp. Good enough for me.
How are you going to make a post like this with no pics? :D
I'll fix it
https://i.imgur.com/ce3RUZ4.jpg HD
https://i.imgur.com/FfhTjLI.jpg HD
I agree with your assessment for sharpening s110v with one exception. I have found maintaining the blade easy with fine and strops. The only difficulty I ran into was when I needed to reprofile the blade. (my bad twisted a little shaving wood and fubared the factory edge.) Took a bit of work on the Diamond rods but I was able to get it back to hair shaving sharp but it was a lot more work than s30v repairing the edge. Daily / weekly touch ups no problem tho. When I initially tried to use the brown medium spyderco rods I think s110v laughed and said that tickled how long do you have?
I think the edge will perform better after a succession of diamond sharpenings to remove the quick belted factory job.
Military is a nice cutter and a perfect specimen to sport the 110v blade.
I like the hook on the butt of this knife for your pinkie. The balance, the weight, the size, the new cqi improvement, just awesome.
That was my real life experience with it as well. After re-profile the blade has been a solid performer for me.
That’s what I’m thinking with my S90V Millie. I little too chippy with the factory edge. I’m trying out a new edge from DMT diamonds finished on brown and white spydie stones. Stripped on leather. So far much better results.
That cerdic and ada guy on YouTube already proved he gets longer lasting edges with his lansky vs worksharp setup. I think it's easy to overheat the edge with belt grinder, especially alloy that takes longer to grind like 110.
Interesting... I'm looking for an S110v or M390 knife. Actually, both of course. But one for now. I missed the M390 PM2, so now considering which S110v knife: either PM2 or Military. Leaning toward the Military...
Yes, but Cedric (aka Pete) is typically doing 17 degrees on his Lansky and going to 600 grit. Not sure of the grit on his worksharp, but it's 20 degrees. I don't doubt the Lansky is getting a better edge. Not sure how much of the improvement is due to belt vs. hand sharpening or the angle.
Nod to Pete of Cedric and Ada, btw. He's got dozens of tests done and is just crushing it in terms of collecting a single characteristic of a steel. He's done some corrosion and toughness tests as well. Those are harder to do when you have a loaner knife, of course.
Edit: I'm guessing Cedric and Ada has helped to sell more than a few Maxamet Spydercos.
