I've had both my Ti Military and My Sebenza apart. The way I remember it, they both have a bronze washer on either side of the blade and a 2 piece screw set in the pivot. One carries tip up, the other tip down. The Mili pocket clip has 3 screws, and the Sebe clip has 1 but the clip sits in a groove so it does'nt rotate. The frame leaf spring on the Sebe is is not covered by the pocket clip, so theoretically it could be hyperextended. A hyperextended spring can be reset by diassembling the knife. The Sebe design lends itself to the pushpin lanyard setup. The lanyard hole is enlarged to fit the pushpin, and a shoelace is attached between the your belt and the ring bail on the pin. To release the knife, depress the button on the pushpin and pull it out.
