Kreole, any chance of a picture of your millie open? I'd like to see how the enlarged choil looks. Thanks!
Sure, but it's incomplete. I'll link it because they're big pictures. I put it next to an unmodified Military to try to get a good comparison, though it might be best to gauge how much was taken off by the change in the bevel on the corner of the handle
http://imgur.com/a/POmzS
Unrelated to the mod, I cut the tip of my thumb, so I haven't finished it yet (that M390 gets scary sharp
). Once I'm closer to healed, I'm going to take it down just slightly more, then add the side bevel just for the sake of aesthetics. Right now just the tip of the jimping is just barely sticking up above the handle, but it feels a lot better, IMO of course; you can see I took a good chunk of the bump off to get to the jimping nearest the lock bar, and that makes it feel much larger.
I did it because, well, if you have a Military, you know about half the lower jimping is unusable. It's tucked away in the handle. It seemed like an obvious mod to cut down the handle enough to make the jimping useful, but that made me nervous because if it's so obvious, why have I never seen it done, or why hasn't Spyderco done it? That part doesn't touch the blade when it's open, so it doesn't help with side to side play. I suspect either it is a remnant left over from when there was no lower jimping--hence no reason to make the handle low enough for some to be usable--or as in this post, just the aesthetic benefit of covering up all of the blade when it's closed.
