Militec not working?
Recently, I picked up a bottle of militec-1 because I heard so many great things, but after lubing it, it will get noisy after about 45 min. I've lubed it once when I first got it, and about 3 more times that week. It just won't stay quiet. I made sure I took a hair dryer and heated it up each time before applying and allowed overnight to settle. Then in the morning I wiped off the excess.
However, after I flipped it a couple times, a bunch of excess militec liquid spreads out onto the blade and the side of the handles, so then I wipe it? Am I supposed to wipe that too? If not, I find it all leaks on your hand when you do rolls.
Thanks for your help
Dave
My collection
I've had the best luck when I heat it up as hot as the hairdryer will get it, put a DROP of MilTec1 on each pivot, on each side, and then manipulate it for a minute or two and then wipe off any excess. I don't think letting it sit over night will do you any good.............
I agree. I suggest using it as soon as you lube it. Work the Militec 1 in real good and wipe of the excess as you go. I have had great results with it.
John
Webmaster of BalisongFans
home.san.rr.com/balisongfans
What do you mean by "noisy"? A rattle or a squeak or what?
Normally, when I lube mine following much the same procedure you do, a bit of excess Militec-1 does come out. I've taken to blowing out the excess with a blast of compressed air before manipulating, but that's just to keep my hands clean. Excess is normal.
Chuck
Balisongs -- because it don't mean a thing if it ain't got that swing!
http://www.balisongcollector.com
How do you get it off your hands? I think I've been ingesting it whenever I use it.
Well, after I first lube it, it is very quiet meaning it doesn't squeek. Other than the noise of the kick hitting the handle, it makes no noise at all. Does it ever stay this quiet after wiping the excess off?
Dave
My collection
If you're not happy with that militec stuff, try "<a href=http://www.whtlight.com/bike/wl.html>white lightning</a>." The guy who sold me my <a href=http://www.premiumknives.com>BM 42</a> (a little expensive) put it on and knife didn't make any noise at all, aside from the handles clinking, and it was unbelievably smooth. Get it at your local bike shop or knife retailer. It keeps the hinges clean too.
if you're not now...you never were!
White Lightening is a wax-based product that contains solids (you can see this in that the stuff is opaque) and, as a result, it works almost instantly. But, repeated use of it has been known to "gum up" a knife.
Militec-1 bills its product as a "surface conditioner". It contains no solids (which is why you can see through it). But, it is supposed to bond chemically with the metal surfaces and reduce the coefficent of friction. Warming the surfaces helps accellerate that chemical bonding process. This is also why Militec-1 takes time to work, why you leave it on overnight. It's also why this stuff takes several applications to throughly bond to the whole surface. The first time I used it, I was unimpressed. Initially, it seemed to make the knife slower and sluggish. The next day, the knife was back to normal, but just normal. It was, however, suggested to me by none other than Vance at Benchmade, so I stuck with it on my balisongs and also on my AFCK. It was on the AFCK that I first realized just how good this stuff is. After the second application of Militec-1, the next day, I took that knife out of my pocket and opened it as usual. I heard the click, but didn't feel anything, none of the usual sensation of the blade moving. I thought something was wrong... maybe the liner lock was broken. But when I checked the knife, I simply realized that it was now as smooth as polished glass. And it just got better.
Balisongs react equally well to Militec-1. It is on balisongs that I realized the endurance of Militec-1. In just a few minutes, a balisong artist can cycle the joints on his knife more times than the average folder gets cycled in a year. No other lubricant I've tried has lasted as long as Militec-1. The more you use it, the better it gets.
Now, as to a squeaky Model 42, I suspect that your screws are set to tight. Even with no lubricant at all, the thing should not squeak. Try loosening the screws just a fraction of a turn.
Chuck
