Millit V2 clip
u812
Has anyone tried one yet? Just ordered one last night.
I have one on my TiLok. I find it a little loose. Maybe someone can tell me how to tighten it. I do prefer it to the hawk clip that comes with the TiLok. I find it too tight. On the other hand I prefer the stock CR clip to both.
I have been having problems with the stock clip catching on everything. They say this new version has more retention than the old one.
OK,got the clip. Maybe I should have waited a while before posting this but here it is. Nice looking clip but I just spent 30 min fitting it to the knife. This is with having the correct tools to do it. I will have to say I am a little frustrated having to fit a 60.00 clip.
After getting it in place I am fairly happy with it,retention is not as good as I would have wanted but with looking at the clip I think the only fix for that would be if they left a knub coming down in the center of the clip. The main reason I ordered it was that the factory clip was grabbing everything. As of right now I do not think that will be a problem with this one. All in all I like it but with the fitting I would have liked to have paid in the 30.00 range for it. I did scotch brite it a little to dull it a little,may decide to bead blast it. Hope this helps anyone thing about getting one.
I have a micarta clip and found it a bit finicky on all models. In the end I sanded it a little and it fits better. Still, cool clips.
That sucks, it does look nice. I carry mine in a pocket sheath so the clip isn't an issue.
Maybe some feedback would be helpful. I think the scotch brite looks good on that side, it goes with the finish on the screws in the pic. It looks sexy.
When you say you had to fit the clip, can you explain what you mean? I just installed mine and it was able to pop right in. Regarding retention, mine actually has a bit too much retention.
I purchased two of the V2 clips. Although I really like them, I am disappointed in the amount of varience between them.
Mine would not fit the slot. It was a good bit of file a little and check fit. Guess I would rather do that as have it to loose of a fit.
Oh and in carrying it a while the retention is not too bad. Used to a Hinderer so the retention on the Sebenza feels a little loose even with the stock clip.
