- Sep 29, 2015
I’ve been needing a decent flat surface for working nickel/copper/brass/silver sheet and have been considering making two mini anvils. I don’t need anything crazy in mass since my plan is to mount these on a heavy duty vise or set them in a block of wood/log or cut them to fit in the hardy on my anvil. I have some mild steel plate I use now for this purpose but I’d rather have something made out of better material. McMaster has 4140 round bars and square bar, was thinking of getting a 3”x3” round bar and a 3”x3”x3” square bar (they would be around $30 each and I’d like to have both shapes).
Would these sizes be good for what I’m looking to do or will I really need something with more mass?
What kind of temps/times would I be looking at for heat treating these kind of sizes? I have parks 50, canola oil, and water. Looking around I see most people suggest water but the post anvils they’re making are much larger than what I’m planning so I’m not sure if that means I should use something else. And as far as decarb, how much material should I expect to be grinding off after? I have some stainless foil on hand if that’s necessary.
Thanks
Kevin
Thanks
Kevin
