mini commander
My mini commander makes a squeking noise when i open and close the blade,tried militec,tufglide did not help. What can i do to fix it?Anyone had this problem or is it only me.
fully dissemble and clean... that's why thankfully Emerson uses the common screw types, rather than the awkward "small as heck" Allen and Torq bits
You might wanna consider making your Tuff Cloth "wetter" in order to clean, unless you plan on using Breakfree or Hoppes oil.
Breakfree might be a good option here, firstly cleaning with it, then following up with a Tuff Cloth coating
It's most likely the bearing. They get a flat spot on them and can squeak. I had the same thing on mine, and it eventually went away with openings and use.
