Mini Griptilian blade swap
Hi! Have anyone tried to swap blades between Mini Griptilians? I was looking for a 555-1 for a while, but I had no luck. I have a 555-s30v now and I really like the opening hole. But the G10 handle with the open back is tempting so I was thinking if the blade would fit into 551-1? I have a good deal for one and I was thinking I might be able to combine them if the blade has the same shape around the pivot. Thanks for sharing any experience!
No you can't swap the blades from a 555-1 into a 551-1. Geometry won't allow it.
Thank you for the quick answer! However I think I made a mistake with the identifiers. So what I wanted to go with is to put the blade of 555-S30V Mini Griptilian to the body of 556-1 Mini Griptilian. If I am correct with the ids, both the donor and the target should be the mini versions. Thanks again!
Oh well then yeah those should swap out no problem.
Match the blades up, if they match, should not be a problem. Pivot holes and lock faces have to match side by side.
Thank you Jimmy!
115 Italian: I have not in the possession of the second one and if I want to compare them, I have to buy it :D This is my reason for asking in the first place
