I've done prying on my Mini Grip. It still has a stronger tip than the PM2, and far stronger than the Manix 2 low hollow grind.
The regular sized grip is about .0126mm~
It's about .012mm on the Minigrip while the PM2 is abut .095mm behind the tip. That small .025mm difference makes a BIG different in tip strength.
The manix is even finer than the PM2 probably .08mm~ havent measured that one though.
Here's some results of my unscientific testing.
My testing showed that Regular grip (154CM) versus a Paramilitary 2 (S30v) had a difference of approximately 2mm in penetration (11m PM2 to 9mm Grip) when stabbing white oak board. About 20% on average. largest difference being about 33%~ which only occured once, most other were in the range of 18%-23%. This test was repeated 30 times (my hands were feeling raw by then. I did not use gloves.
I could not accurately test for strength laterally without having large deficiencies in the methodology (thought about using a pulley system, and adding weight until the tip deformed but found it inefficient). I have no idea on percentages but hopefully this gives an idea:
After about 10 stabs and prying chunks of, the Griptillian saw a small .01mm bend on the tip~ very small. The Pm2 saw immediately and considerable tip bend after about 1 stab (im thinking nearly one millimeter.
I've bent my Manix 2/PM2 doing simple whittling tasks, this is what prompted my testing. Manix 2's tip was deformed when doing some stabbing tests on the video I have on my youtube channel). I had to straighten it out. I am 100% certain I could break the Manix 2's tip on wood. The Pm2... maybe but I would have to be dumb to keep whittling with a bent tip, but certainly possible if I hit a knot and force it.
