mini-manix
hey does anyone knw if the mini-manix can be dis assessmbled , anyone knw what sized washers it uses and if anyone has pic that would help alot
Don't have pics but, the Mini does tear down quite easily. You need TORX screw drivers. You need to know you must "back up" the screws on the other side of the knife with another TORX driver (as, held in a vice)
Find the "screw" side of the pivot pin (not the pin side). Remove all the screws on that one side and seprate the halves, there you have it. You can remove spring tension by pushing pivot pin out or leave in tension while you clean.
Put it back together in reverse. Use blue Lock Tite on threads.
you comment was much appricated it worked out well i was going to change the washers to pb but it was aalready like that lol i was kinda suprised have a new found love for spyderco thanks again
