Mini Review - AZ Welke BK4 Machax and BK14 sheaths
Bladite
ǝɹnsıǝן ɟo uɐɯǝןʇuǝb
Moderator
well, you know sheaths... but perhaps not in these colors:
and wow, that seems to have come out bright... perhaps too much "awesomize" on the filter :>
flexible strap is flexbile! some kind of thick tough vinyl like materal, it's not kydex, if you were wondering:
back side showing "loop" - very cleverly made of a single piece of kydex, and shaped. edges are SMOOOOOOOTH. good touch that. note the new stamped logo too:
good looking hardware, and of course, removable and adjustable up and down, or even replaceable with something else:
it's almost like the hole spaces are built on some kind of standard template, so you can zip tie, bolt, or otherwise go modular - now i just need to get some rubber washers and cool spacers:
fit and finish on both is impeccable. edges appear to be heat polished to they're SMOOTH - no biting or cuts. lockup is tight and in the case of the Machax sheath in particular, almost zero rattle even when you try hard - due to the taco pattern, there is SOME slight movement, but you gots to try. the BK14? nope. SOLID.
purple is the new black :)
thanks for the good work AZ Welke :>
that BK4 sheath pastern is pure genius. I been admiring that since I first saw it...I actually even dig the purple on your set, kinda cool.
holy crapinoli.
that is the most highly filtered sheath I have ever seen.
While I mostly lurk in this section, (I do own an 11 with micarta scales) I've got plenty of Al's sheaths & his work is really top notch! He also keeps ya' informed of shipping & real easy to deal with! I'm waitin' on a 20+" taco pancake from him as I type this.
Al's sheaths are truly something beyond awesome.
I have one for my 9, and damn, what a sheath.
Moose
Did you supply the kydex or was it something he had ? Machax sheath looks great and easy to deploy the knife.
Sheath design = Legendary.
Color = I didnt know Bladites day job was playing the purple teletubby.
Pink would have suited you better.
matches the blanket.
nothing wrong with pink though, i'm secure in my person-hood :>
also considering an AR platform in fuschia ;)
