its funnny that you bring up how the forces load and how a well done knife spreads the load over many different areasI cut my slots with a 1/16" endmill. The problem with trying to go smaller is that framelocks are thick, and smaller endmills simply don't offer enough length to make it through the full thickness. I wish I had $85K for a wire EDM.
However, the width of this slot really has no effect on the performance of the lockbar. If the lockbar twists, or deflects vertically, or some other thing, it's because of some other geometry that's not right. It's like using a 2 x 4 when you need a 2 x 8.
A lock is a beam, and if the designer of the knife does his job, the bar will be of the proper proportions and dimensions to react the loads applied to it during use. If the geometry is right, the load from the blade will act directly along its length (and therefore will not try to deflect the locking bar upwards or downwards).
I hope this is clear and not too technical.
