Mirror Finish Grits?
Guyon
Biscuit Whisperer
Super Mod
Somebody take me through the various grits I'll need to restore a mirror finish.
I have a blade with an ugly etching on one side. I would like to remove the etching and then restore the mirror finish. Can I do it with just sandpaper of decreasing grit size and patience?
Here's the quick and dirty:
use wet\dry paper (it is black). Try starting at 220 grit (that etching will take a whiel to remove). Baclk the paper with something FLAT like a very hard piece of wood, or some such thing; I use micarta. If there are curvs to sand (ollow grinds, for example), it is best to shape a wood block to the curve of the hollow. Alternately, you can just use a piece of leather, but it will take longer and might not produce as even of a finish.
You'll want to go 220, 320, 400, 600, 800, 1000, and up. The lower grits take a while, so dig in and be patient. From 220-400, you can do back and forth strokes. Actually, you want to change the angle slightly with each grit change (go lengthwise with 220, widthwise with 320, lengthwise with 400), so that you can see the old grit lines disappear. From 400 and up, just do lengthwise strokes, and go in one direction only (ricasso to tip). Otherwise, you get swirlies!! I like to use baby oil when sanding, I find it speeds things up. Messy, yes. If you have access to a buffer, you can stop around 600 grit and buff. Otherwise, go as high as you want with the grits. Use paper liek it is free! Once a piece stops cutting, use a new one!
I would agree with Crayola, and add that for a genuine mirror finish you must keep going in grit sizes above 1000.
I use 2,500 and then jump to 9,000.
Both these are PSA type papers got from Lee Valley.
It is the 9000 that gives you the final mirror surface.
Heed Crayola's advice about making sure you have sanded out all the scratch lines from the previous grit.
If you forget to do this, you will finish up with a mirror finish with some deeper lines left over.
Then you have to go back and re do things.
Use leather left over bits as backing to save your fingers.
Done well, it is most satisfying.
