- Jun 20, 2006
I have a Benchmade Valet that I have been waiting to sharpen a year to the day for lack of proper stones.
I have seen Chosera and Shapton mentioned as top stones and only want to buy gear once. Not save money and then upgrade.
Please answer any of the following if you are confident in your answer(s)
1. True or false: anything that can put a true mirror finish on m390 will be able to do the same thing on any other steel capable of a mirror polish.
2. I want to avoid soaking stones or oiling stones unless completely necessary. Preference would be stones that just need a spritz of water and occasional removal of slurry.
3. Confusion over "pro" vs. "glass" line of stones- do they both have their niche or is one better in majority of instances.
4. Microcrystalline abrasives- are these stones I should get or strop polishes. If strop polishes, dedicated strop for each paste?
5. A bit off topic, but I confirmed Benchmade only delivers knives that are flat ground. Is reprofiling my first order of business?
The Valet in M390 is my EDC so will see mostly cutting food away from home and normal tasks except for opening boxes, which I feel is not an appropriate job for a knife when a slightly sharpened flat bottle opener does that job just fine.
I am also going to purchase 3-4 other knives in "supersteels" to form my own opinions on their relative usefulness for my needs so any stones purchased should be able to handle even the most exotic steels.
Finally, I sharpen knives of all sorts for friends and family so would like any thoughts if for some reason the high end stones should be reserved for only high end knives (ruining stones by clogging with "inferior"steels)
I understand that a mirror finish is for aesthetics only, but would like to do this anyway.
Thank you for your time.
