I use a set of Helios (calipers) set to the right size,
if I'm not eyeballing it,, which I like to do most the time..
I have them anyway.
I'll just set it to half the size of the steel
let's say your steel is 0.130,
divide it by two = .065 center of the sharpened edge, (where it will be when finshed.)
and add to it one half of what you want the edge body to be,
lets say the edge body is to be .025 then add to that meat to
grind after heat treating
= .0125+ plus the meat to finish grind.
I want to confuse you more by saying you can get the same lines by subtracting everything after the first 1/2 measurement.
lay the I/D ( inside) of one of the tips to the surface like
you're going the measure down to the edge
( where the edge will be ) scribe and then scribe
from the other side.
using some bluing die or (sometimes called) die-chem to
see the lines better. did that make any cents
this is why I don't write books
