- Sep 4, 2004
I've been stropping knives for years, but am a little embarrassed to admit with varying degrees of success. With compound like CrO I've never been satisfied with results I get on smooth leather..... on rough leather it's much better, particularly if the blade has a pretty low edge angle.
I've read a bunch of stropping guides and posts on forums. Maybe I'm not holding the angle steady? If not, how do you do it? (I can freehand sharpen fine so I don't think it's a motor control deal.) HandAmerican's suggestion of raising the spine till the edge just bites the leather then backing off slightly doesn't work even using blade-weight only pressure and being careful not to lift the spine at the end of the stroke.... I either get no improvement or round the edge. And if I do see some good result it's only sections of the blade. BTW I can do tools like chisels, I assume because of the large flat edge.
Any suggestions or tricks? Or should I just stick with rough leather and low edge angles? Could it be leather that's too soft, or too hard, or too much compound?
