MLL Knives
MLL Knives
- Jul 26, 2012
MLL Knives
Special Custom knife pack.
A set of two knives, the BIG SPECIAL Custom and the AMAZON Hunter.
The small knife use a "piggyback" leather sheath that attaches to the big sheath. Singly you can use both sheaths vertically and horizontally.
BIG SPECIAL Specs:
Blade Material: O1 textured steel.
Handle Material: Black/Desert G10, full tang construction.
Sheath: Brown leather sheath, vertically or horizontally use.
Overall Length: 14.1/2" (~370mm).
Blade Length: 9.1/2" (~240mm).
Blade Thickness: 0.236" (6mm).
Blade height: 1.31/32" (50mm)
AMAZON Hunter Specs:
Dimensions: OAL 9.133" (232mm) with a blade of 4.448" (113mm) long by 1.377" (35mm) wide and a spine thickness of 0,177" (4,5mm).
Blade Finish: Hand rubbed satin finish.
Steel: BOHLER N690 stainless steel - a modern stainless steel designed for use in high performance knife blades. Great value in a corrosion resistant knife steel with excellent edge holding capabilities. Additions of chromium and vanadium enhance edge holding capability, while cobalt and carbon help to retain high hardness.
Handle Materials: G10 a high-Tec reinforced plastic, ergonomic handle design, full tang construction, stainless steel pins.
Sheath: Handmade leather case, double stitched construction, integrated belt loops for horizontal or vertical carry.
BIG SPECIAL Specs:
