- Aug 25, 2003
Well, I finally got the old Mickey Mouse Grinder running.
I only wish that I could get the pic to show up, but you should be able to see it by clicking on the URL
As you can see the motor mounting system is pretty basic
What the heck
The tracking system works very good.
I had to do a little tweeking to get it to run straight, but it is fine now
I know you're wondering "How Much?", but little baby really didn't cost much at all. I did have to buy the motor, controller (a la "KMG on a shoestring), wheels Platen mount, pulleys and flange bearings, but hey, I think the whole thing cost me about $250. Not bad really. Of course that's not counting the actual time spent on it, a long time from beginning to end, but being the procrastinator that I am, not much time acutally working on it
The motor is a treadmill motor (1 1/2 HP) that spins at 4000 RPM, I know that I don't need that much speed, so I used a 2 5/8" dia pulley on the motor and a 5 1/4" dia. pulley for the drive shaft. This cuts down on total RPM and increases torque. And it has plenty of torque for what it is (I can stop it using excessive pressure).
The platen assembly is similar to one that I saw at a bladesimths, using the 2" wheel on top with a 4" contact wheel on the lower portion, I just made a cardboard templete of the actual platen that I will be using. I'll take the platen to work tomorrow, and get the material (ie 4" X4" angle bar 8" long) and probably do the cutting and fitting at home.
What do you call the stuff that you put on the platen to cut down on friction? I will need to put a piece of that on the platen.
Maybe someday, I'll finish knives with it and they will be good enough to sell, then I can justify getting a new motor, but for now it'll work just fine.
Larry T
Member of NECKA & NCCA
What the heck
Larry T
