Mnandi clip on small sebenza
I was curious to any of you with both a mnandi and the small sebenza, can you put an Mnandi clip on to the small sebenza? Or do they use different sized screws?
The Mnandi clip requires a hole in the scale to keep it from rotating. You will see it on any Mnandi picture out there. The clip has a post that goes in that hole. Also on the new clips the clip is the screw and needs the post you see on the other side. On the old model clip the screw might be compatible but you still need the anti rotation hole to be drilled.
