Mnandi Question
Hey guys:
I just got this NIB in a trade and I freakin' love this critter! It's the little knife that acts like a big folder!
Anyhow, my mnandi is a lefty...is there a way for me to switch the clip to the other side?
I used the wrench to undo the screw that was holding the clip in place.
When I took that off, the bolt (I may be using the term wrongly here) that it was screwed into did not come off, so I couldn't switch it to the other side. The head of this bolt is flat, so I can't use the wrench to remove it.
Does anyone have any suggestions?
Thanks!
The threaded insert should push out allowing reversal of the clip.....I did mine easily. Try putting the screw back in after removing the clip and run the screw in several turns but not quite tight. Then holding the knife (closed, of course) as a hammer, GENTLY tap the screw head on a non-marring surface and it should free the insert if it's stuck or tight.:cool:
