MOAR BK11 sheaths...
Finished up a couple more. This first one was a custom order, it is similiar to a sheath I did for a Buck Paklite.
This is next one is a redesign from the X Loop sheath I released last month. I made it a little wider to fit larger belts. 1.75" is the widest belt I can accomdate in this sheath.
I am pretty satisfied with this design, so I will be replacing the old design thats in my online store with this one.
Oh and BTW, clich this one is yours ;)
Goose, I'm loving your new design on the 11/14 sheath!!!!
Clich you're a lucky fella!!
I probably should be able to catch this but for the moment I'm lost in thought:) (doesn't happen much believe me) :D
what is the eyelet for on the strap..??
Probably to hang a little photon micro light off of. Have seen this before.
Looking good!
I tried to email you but its not set up. What tool do you use to install the snaps?
Looking good!
Was it about a sheath for a Mcurdy Kukri? If so, I just replied back to you.
I use a modified 1 Ton Arbor press that holds Tandy set snapping tools. Sooooo much better than using a hammer to set them ;)
No I wanted to ask you my question on the snaps through email. Thanks. Looks really good!
