I just looked through a few of my old posts on this subject.
Copied a few here.
Ok folks,
Modified INFI cannot be readily Told from regular INFI in the field.
Not more sensitive to rust, not more likely to chip.
Not quite the edge holding capacity, I read about the difference in tests, but I do not see a difference when I use them.
Edge holding better than (in soft clean material) any other non-INFI knives known to man so far.
If you like the handle material, and it is comfortable for you these knives(the Basics) Have no non-INFI equals in the world.
SR-101 is more flexable, and better for cutting dirty/gritty material, and better IMHO for chopping mild steel bars and cement blocks. But does not compare in edge retention in soft clean material.
I have and use/abuse abit all four types of knives, Early INFI, Modified-INFI, later INFI and SR-101.
I have a certain fondness for the Basics.
P.S. I know "Secrets" about Modified INFI, get some,,,,,you will like it if you like the handles.
__________________
Andre DuMouchel
INFI/Modified INFI Work in the field close enough to the same That I cannot tell the difference, except for a few early INFI knives that were hardened slightly harder than all later INFI knives.
I am a BIG Fan of Modified INFI maybe down the Road some day Jerry will let me tell you why.
SR-101 is better for some applications than INFI, Cutting Sod for instance, cutting dirty grity materials or hard materials like Cement blocks or mild steel.
Nothing compares well to INFI/Modified INFI when it come to edge retention in a big chopper cutting soft clean things like wood, leather, rope, skin,flesh and Bone, yup thats right bone is for the most part in this context "Soft"
Resharpening is where INFI really shines, it stays malleable and ductile after hardening with the special heat treat and remains flexable like a spring as well.
This means for the most part when you get it dull you need only to straighten or steel the edge as opposed to needing to remove steel to sharpen the knife, Steel and Strop then get back to work.
In rope cutting Edge retention test INFI is first among all big knives Modified INFI is Second, I do not know where SR-101 falls in as I have not seen or read about this test being done with this steel.(And am to LAZY to do it myself)
SR-101 seems to out flex and return to straight better than the other two.
INFI/Modified INFI is more rust resistant.
To much typing, thursty, must drink now, Bottle empty, must search for more
__________________
Andre DuMouchel
Rant on,
Do a bunch of cutting and prying and hammering with the three knife types listed.
The Sr 101 will out flex without taking a set, and will hold an edge better in gritty materials,,,and it will be a better choice for chopping cement blocks or steel because it is not as malleable as the other two.
The INFI/Modified INFI will hold an edge longer used cutting clean soft materials like wood, cloth, rope, meat, hair, and is easier to bring a working edge back(resharpening)
Pry with INFI/Modified INFI you may put a "Set" in the Steel,,,,but you are not likely to ever break it by hand without a cheater bar,,,,
I have done TERRIBLE things to INFI/Modified INFI knives(Made a Basic #3 where you could use it to make bowls, I bent it so much.
Then I just bent it straight again.
In use I have seen almost no difference between INFI and Modified INFI
The differences I found were only in the heat treat.
The early INFI was harder than the rest and would some times chip when you hit hard wire or a hard stone in concrete.
The rest of the INFI and all of the Basics just deform, and you can bend or steel the malleable metal back into place.
In the field I have found no difference I could see in hard use between INFI and Modified INFI, in the "Lab" ? sure,,,in the field nothing else comes close
in a big knife.
I am not a big fan of the Basic 5,,,I only have one,,,my wife has another.
I Love (pet, fondle and Abuse) the Basic 3 and give them as gifts.
If you like the handle, The Basic # 9 may well be the finest knife on the planet for its size.(I have half a dozen or less left) I just seem to keep buying more, but people keep needing them worse than I do.
If you do not like the handle,,,,get a SteelHeart or a Battle Mistress, I did, they will do.( I have a few)
Rant off.
__________________
Andre DuMouchel
