Mod'd micarta?
NJBillK
Custom Leather and Fixed Blade modifications.
Just curious if anyone has any pics of modded micarta scales?
I have been messing around with a 1x1 and reamer bits for my drill, my dremel, drill bits, anything I can find. I am trying to come up with either a patten or random conglomerate of shapes/dings/dents/cuts that will yield sufficient amount of grip while minimizing hot spots.
This is for my 4, so chopping and rubbing is a concern.
Thanks in advance.
You could try sanding it with 80-grit?
IMO, the stock Becker Micarta is damn grippy without any mods.....not trying to be a smartass, but have you just put it on and used it for a bit? For the $$'s of the stuff, I'd give it a really long test period befor I did anything to it. I've got it on my 12, 9 and a tweener and IMO it rocks stock.
I was planning on taping off/drawing faintly with pencil to sand, shape and keep stock.
Sanding the back strap area for pull cutting, pulling down the top of the front shoulders a bit for a bit of clearance while on a back swing when chopping and the scales right side on the heel where it contacts my Palm due to it creating a hot spot also when chopping.
If I do anything, I will mock up a set in wood and rough that out and get an idea as to how it will feel in hand prior to taking my micarta to the grinders/files.
I generally will go with 100-120 to pull off any polish/high grit work, then to 80 for general usage and 40-60 grits for my knives that see a water prominent environment. Sometimes I will use 40-60 to touch up key contact spots if the knife is a small, 3 finger fixed blade for a more textured feel (inside a finger choil, top of the spine near the ricasso, for under the first knuckle)
GSoM: I have used micarta before and while I know what these feel like stock, I also know I generally prefer sanded micarta. That being said, you Do have impeccable taste, so I will give them a fair shake in their current form.
I've touched mine up here and there with a little rat tail file.
Mostly just to make everything flush on the tang.
I haven't ever taken a serious amount off. I'm kinda scared to. Once it's gone it can't go back on...:D
If you do end up modding it, make sure to let us know how it goes.
I'd be interested to see how it turns out and hear your thoughts and review.
