swonut
- Jan 1, 2007
Slow morning this morning, so I decided to add some spacers to the Production Bushfinger. I had previously ordered some green G-10 in .06 in thickness for the project.
Using a set of T10 screwdrivers, I undid the handle screws. Tight, but no lock-tite that I could see. All the fasteners were adjusted during the assembly process and the lengths varied. (This would come into play later when I had to swap screws around to make the combos longer. I also removed a little burr on the short tube-bolt.
From there, I traced the outline of the knife with a sharpie and then cut it out on a bandsaw. Next I drilled the holes and then reassembled the liners on the knife to rough our the shape on my Cheapo 1x30 grinder with a 40 grit belt.
I then worked the top of the handles after I put one of the scales back on. My belt started burning, so I swapped out for a sharper one. G10 was tough stuff. I went to a 120 grit belt and stopped there. I should have hand sanded it further, but I didn't. Maybe I'll take it apart and work that a little bit.
From there, I reassembled the whole knife and then carefully worked it on the 120 grit belt to even the handle with the spine. I could not get into the index finger curve, so I switched to a sanding drum in my drill press.
After that, I hand sanded it through 600 grit. I bought this sandpaper pack with my wood lathe and it's been the bomb having all the grits available in little pieces.
A little rubdown with oil and here are the results:
I did bump the logo with the belt, so I recommend taping up everything, not just the blade.
If you like the fat fiddlebacks, then you will LOVE this mod. It makes the knife feel much like Andy's older handles.
Hope this gives you guys some ideas.
