Chris I think 58 Rc would be too hard for a kukri hardened all the way through. You could probably get away with 54 - 55 Rc but I wouldn't even want that even though some knives are only 52 Rc, the Okapi African folders IIRC.
The full hard modern knives like the Trailmaster aren't spring steel and therefore will handle the full hardness although a person would be better served if its spine were softer like a kukri and what I consider most really good Bowies.
And with Busse you're comparing Washington Delicious Apples with Brazilian Mangoes with their INFI.![]()
However with all that said I personally think that a person would be better served with the edge hardened from the kaudi (cho) too the tip instead of as they are. Or at least quite a lot harder in those areas than they are.
I understand why they're made that way and especially for use in Nepal and other countries with similar fauna and terrain.
And how have you and your beautiful bride been the last while?You haven't been around in a coon's age it seems!
Hey Chris...
I always wished the kamis would have hardened the SARGE knives all the way through. For a woods knife/sheath knife, seems most appropriate. Don't think it happened though. Wonder if the the R6 R7 mods are hardened throughout.
Nice to see you posting.:thumbup:
I don't think that the R-6 is hardened all the way through. At least mine isn't. The tip and belly seem to be pretty hard, but the spine feels softer when i push a file along it. I don't think that the sharpened clip is as hard as the edge either. I really ought to etch mine to find out for sure. It needs a good scrubbing anyway.
Hi Yvsa,
Good to see you too!
Chamaine is really good and is finally out of school! She acctually asked me if you got off all those meds you were on and feeling better?
I was wondering though would a nice draw temper even out the steel and get all the stress areas and internal micro cracks out of the steel from when it was shocked when the water hit it from the Kami?
Thanks Chris and thank Chamaine as well, sorry to say I am now up to number seven with the amount of back/neck surgeries and so far still going strong with the meds.![]()
As far as the kamis shocking the steel when they pour the water on for hardening I don't think it is "shocked" all that much as I understand they use very hot or boiling water for hardening the edges.
We have had quite a few discussions in the distant past about how the kukris are hardened and what happens seeing as how the kukri isn't actually tempered by "drawing" the hardened steel in an oven.
The consensus was that the still very hot steel that remains in the body of the kukri, "draws" the hardness of the edge back from the very brittle state it would otherwise remain in.
Uncle Bill once told us that Bura told him the water was poured along the edge seven times and that the kami had to watch the colors change so that the edge would be as it should be when finished.
It wouldn't hurt to put a kukri blade in the oven and "draw" it back but I personally wouldn't bother.
If a kukri doesn't fail when you do the initial proof testing, providing you proof it properly, it's doubtful it ever will.
Have you had some kind of experience with a kukri that would lead you to ask/wonder about this?
You might ask Ray Kirk if he would be willing to do it. He does a great heat-treat on 5160 (which is closest to what the spring steel seems to be).
