well... i got me a public defender... but i quite soon found out that this thing is not meant for active cutting, ala the active duty. im not quite sure what it was specifically designed for... so, i wanted to take the primary grind up about a 1/4 inch, to thin the whole thing out. so i took off the finish, and tried my best to sand paper some of the metal off directly behind the edge, and found that to be impossible (dont wanna spend a month sanding 6 hours a day...), and then looked at my available options for grinding the primary - and found that i just didnt want to throw a 200$ knife into the trash by putting a completey innacurate grind on it.
sooooooooo, all i ended up doing was taking the coating from the blade, sanding out some of the major pock marks in the spine area (one of them was a bit to big to get out), and brought it to 24 degree's on my edgepro apex, with 3 bevels at about the 21, 18, and 15 marks. the thing can now cut like any other blade, though for tasks involving pushing the material across the length of the blade (from edge to spine) you realy start to feel the difference between a full flat grind and a traditional tanto (?).
also, i curved out the area by the spine a bit more... (where primary meets spine) so that when you get to that point, it helps the material glide past it...
if i could sell it to someone in its now mangled (aesthetically, and minus a fair bit of the metal directly behind the cutting surface), i probably would, and replace it with the ad-tac that im gonna get... but, im ashamed of it due to my lack of tools, and my impatience with super extended sanding tasks. ill probably keep it for a long while as my car stabing/thowing knife...
not really modifications like your speaking of, such as putting a swedge on it, or putting a recurve or serrations, or new handles... but i did WANT to modify it
