Modified Cold Steel Shinobu tanto
Sometimes i buy used older knives to restore, but also as practice material to try out certain idea's.
The tanto point on this used & worn 1980's Cold Steel Shinobu folder was made a bit pointier with the help of my Tormek T7, then sharpened & polished on a first generation Wicked Edge.
The straight edge was done freehand on Paper Wheels with diamond compounds.
The rubber grips were also re-attached to the liners (as they had partially come loose)
How these knives look from the factory (pics from the net):
How my knife looks now:
A test i sometimes do just for the heck of it is to see how far from the point of holding one of my chest hairs can still be whittled root-to-tip (reverse hair-whittling) while holding the hair at the root end only.
The edge on this modified Cold Steel folder could do it at around 1.18 inch (about 3.0 cm)
Now i don't own a BESS tester, so i have no idea where this would be on their scale.
All work and no play makes Jack a dull boy, :D
Imo the Shinobu model would be a good candidate to bring back, of course with a Tri-Ad lock, a more modern steel type, a better synthetic rubber handle (Resiprene-C if possible) or even canvas Micarta grips, and maybe even a pointier tip, :cool:
