Modified productin slipjoint, took some time, but I like it.....
After holding the one blade Buck 301 solitare, I was considering other knives shown on theTraditional forum. Several other companies had two blade knives with a clip and warcliff blade. Since I have not 'spayed', an animal in a number of years and seldom used a spey blade I then considered, we ought to have two blade Buck 301 and 303 stockmen, sans spey blade.
So I shipped off a Dymondwood scaled 301 and 303 to a Buck knife guy and asked the spey blade be removed. After a good period waiting in the work line I received back my modified two blade 301 and 303 .
Here is a bottom shot with a regular 301 on the left, my two blade in the middle and a single blade Solitare on right.
They also trimmed down the Buck Sheepsfoot blade, to look somewhat like a warcliff blade. Modified blade on left, normal on right. The nail nic limits what you are able to take off, in the effort to trim the end to a warcliff-like point.
After receiving the knives I felt the blade kicks could be shortened to give the knife a cleaner, more linear look. So, I carefully ground and polished them myself. I carefully watched the closed blade depth, so as not to bottom out. I tried to go to the level that the nail nic was just a hair above the liner edge.
After photographing these pictures, I now think the main clip blade could be lowered so very slightly to even improve the line somemore. I really like the width of these knives. I hope someone from Buck will consider this alternative, hey maybe I need to send one to Joe Houser in Buck Customer Service to carry around.....
I may get excited enough and take some time and put some burl wood or jigged bone scales on these and carry one of them proudly as "exclusive" models.....
I lowered the clip blades in the blade well using the same careful process. I kept the nics above the liners, I wanted the top of the curve of the 'speycliff' blade and the top of the clip angle almost level.
Here is the 301 and 303, got a good level on the 303 but stopped a little short with the 301. I may can go down level but need to get a strong light and look down in blade well to check situation out.
Here is a end shot of of the same. Tweaking the kicks on the blades lowers the "push" from the angles in the palm of your hand, actually your fingers. This is hand fitting work, a factory would have to charge a bunch for this if they tried it on every high production knife.
300Bucks/ch
Very nice mod you got there, looks great, and i guess carries much better.
In the last photo, is the right liner of the 301 bent, or is just an illusion from the angle ?
even the 303 liner looks a bit waved.
You can't fool the close-up. The shop that did this said they had to take them all apart to do the job including the scales. I.E. Notice that the spring rivet is hidden under the scale. Also let me state these were not that way at factory issue.
The end of the 301 picured is bent/ gaped right at scale rivet area, I had a second 301 done and it is all fine. The 303 looked 'wavered' to me also. After the photos were taken I was able to easily slip the tip of a small duck billed plier in the bladewell and it straighten right out. I should have had them put on some nice jigged bone or stag scales but didn't want to go to the bank for a loan. That would have eliminated the difficulty in trying to re-attach factory scales after removal. My goal with this project was to promote the factory to do a two blade issue.
Before comments come, yes I should not have recieved those problems back after a custom shop worked on them. So noted. 300
Hope the promotion works. Great idea!
"I may can go down level but need to get a strong light and look down in blade well to check situation out."
This can also be accomplished by cutting a piece of paper perhaps 1/4"wide by 3" long. Fold the paper in half (it's now an approximately 1/4" x 1-1/2" open end loop). Keep the blade you want to lower in the closed position. Hold the loose ends of the loop between your thumb and finger and carefully slide the closed end under the blade starting from the point. You can then pull it up gently until it just makes contact with the edge. Do this in several spots along the edge to determine how much clearance you have left. Hope this is clear!
300Bucks,
I think you're heading in the right direction. In general, I would love to see Buck increase their offerings of slip joints and I think 2 bladed knives make sense for today's market.
One knife I would love to see is a variant of the Canoe with the small blade replaced with a bottle opener. And made in the US out of 420HC. Well, one can dream....
Those are great!
Buckthorn - sounds like you are describing the "dollar bill" trick for inletting a rifle barrel into a stock, if I read it right.
-Xander
A 2 blade version like this would have a lot of appeal, very interesting project.
I'd definitely give the two blade 301 a home, if they decided to put one out. I am very happy with my 301 and 302 single blade solitaires.
Ed J
fast14riot
"Buckthorn - sounds like you are describing the "dollar bill" trick for inletting a rifle barrel into a stock, if I read it right."
I don't know that technique but it could very well be the same thing. The longer I do craft work (34 years now) the more apparent it is that very few methods and techniques are truly new. I encourage all of us to borrow from, and share with, crafts other than the ones in which we normally work.
Buckthorn- we are talking about the same basic trick. With rifles, you take a green back and wrap it under th barrel while pinching the two ends together over the top and slide it along the barrel until it touches wood and that's where you know to remove wood from inside the stock.
You are right, there are very few "tricks of the trade" that are new anymore. Just a new generation of users to "discover" them!
-Xander
I think that would make the knife about 2mm thinner. I like the idea. :thumbup: A mini trapper with a clip and Wharncliffe (instead of the spey) would also be cool.
